in prep for plowing snow with my 2010 3500, im checking to see if there was any resolution to the following. when running the plow, the exterior temp gauge (which i believe to be behind the grill on the drivers side) is blocked from getting air flow in amounts to allow it to indicate real outside temp. i had thought about moving the sensor, but was hoping a fix would be created. i read the tsbs in the last tdr mag, where the cab chassis has a feature that allows the fan to run while plowing. couldn't activate it by pressing the exhaust brake key + the cruise control cancel switch as indicated in the mag. any thoughts on how to get a correct outside temp reading while running the plow?
