I'd like to carry extra fuel at times but do not want to have a permanent installation in mmy truck bed or have to remove the spare tire for a behind the axle tank. I have thought about buying a 30 gallon tank and connecting it to vent line so I can gravity fill the main tank in an emergency. It would be easy to route a small line down through one of the tie down holes in the bottom of the bed, and install a manual valve and quick disconnect on the aux tank. When empty it could be easily lifed out of the truck. If I interpret the DOT regs correctly you cannot have a gravity feed going directly to the injector pump but gravity feeding the main tank would seem to be OK. Am I missing something or is there a simpler way to do this other than carrying five gallon tanks?
