A bit of back story:
My Holset HX35 seized so I replace it with new one. I changed the oil and filter at the same time did over fill by a 1/2 quart or so.
All went well and my test drive was uneventful...it was good to have the truck back. It has just shy of 395,000 miles and runs like a top.
Now for the problem:
I drove to work earlier this week and notice a faint oil smell. I dismissed it since the truck has always leaked a "bit" of oil. Not unusual for a truck with that many miles. I drove home at the end of the day and notice a rather large "puddle" of oil under the truck after I got home.
Having given it some thought I figured I'd torn the rubber host on the turbo oil return so I tore that off this morning...it was fine.
I fired it up in the driveway and ever after running it didn't seem to leak...so I took it to an engagement about 35 miles away. The burning oil smell was very strong on the way down and, by the time I hit the parking lot, it was leaking bad enough to leave marks to my parking spot. I suspect it leaked about 1/3 of a quart after stopping.
So...did I screw things up by over filling? I did a bit of searching and now one seems to concerned. I did notice a slight jump in oil pressure (factory gauge) but wasn't concerned. I'm thinking of tearing into the front end tomorrow morning and replacing what gaskets I can get to but I'm also concerned it's a front main seal.
Thoughts...suggestions...a shoulder to cry on?
Thank you!
Thank you!
