Engine/Transmission (1998.5 - 2002) EZ acting up
Engine/Transmission (1998.5 - 2002) Mach 4s are wicked!
2nd Gen Non-Engine/Transmission Spongy Brakes - How too bleed
I have an EZ on my truck. Long story short, sometimes it works, and others it doesn't and I have stock power. All the connectors look good and free of corrosion. Is there and connections inside the box itself that are known to cause trouble?
ours went bad kept throwing overboost code took a long time to find the problem good thing my truck had the same ez as my boys and it tested bad
I had same problem. i called edge told them problem said they had trouble w software and i sent it in. They were a pleasure to deal w an was a fast turn around. My suggestion is contact them
