EZ and DDIII's on '99 w/DDT VB and TC OK?
Dual Range splitter
new member with questions
I know that DDIIs and EZ are OK, but was wondering about the III's. Are EGTs going to be an issue without going to a 4" exhaust?
'99 4x4 • SB • QC • 3. 54 • LSD • AT • Leather • Mag-Hytec • Westach Guages • Line-X • Tommy Gate
Don, you want to go for DDIII's? I was thinking about the same thing. Let me know if you want to go that route.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package,Tow Package,DTT's
TC(91%)&VB(80psi),DD2's,EZ,HOT PE,K&N RE-0880,Cummins RED Valve Cover
I'm just looking at the initial cost difference and thinking that if I could get away with the 3's w/o having to do the exhaust at the same time it might be a route to take.
From other posts I've read, an EZ and PE with the 3's need the 4" and an HX-40. Since I'm not planning on the PE or equivalents any time soon...
Maybe since you have the Hot PE, you should step up to the 3's... . and sell me your 2's and the EZ!!! #ad
We'll have to talk about that one. I can get an EZ for you, if you're really interested.
Fred Swanson
Co-Owner
One of these days, when I manage to save some money, I will be ready to Bomb. I'd like to go with the outfit that's been described above, PE EZ box w/ DDIII injectors (or even better, DD's version of the EZ box). How would this affect EGT's? I want to be able to hook up and tow without worring about temps. Also, would the cruise control still work? I seem to remember reading some posts sometime back that said there were problems with the cruise when performance was increased.
Randy Jones, San Antonio, TX, rdj@gvtc.com, 98 1/2 QC, 4X4, American Racing BAJA's, 285/75/16, Amsoil throughout, Superstar 3000 export radio, Firestik antenna with fender mount, Fire-ring cable, Mag-Hytec Deep transmission pan
2000 VW Jetta TDI, auto, 45 mpg average
Ok right now I have the EZ and Power Edge with 4" exhuast and DTT vb & tc and with the Power Edge turned off the EGT's have not been a problem with normal driving & tromping it--you just got to watch them that's all, but I don't think you'll have a big problem until you add the Power Edge then you need to watch them if you stomp on it from a dead start(they go crazy), but if you're driving along and hit the #2 or #3 setting with the boost already up it's a lot better--you'll still have to watch them though as the 3" exhaust will probably limit you a little more than my results... ... get 'em is my vote... . chris
When I started the bombing on my ram, I made took baby steps. Started with the PE (EZ was not out yet), temps were controllable. Then added the EZ and the temps stayed relatively the same. Then added the DDIIs and EZ+PE+DDIIs forget it, I couldn't use lavel one wot without hitting 1400 preturbo. Added the HX40 and my problems are solved, With Hot PE on level 4 max egt is 1450. I would like to go to DDIIIs now but need a home for the IIs.
I would advise that the EZ+DDIIIs could be used in your situation. Baring you monitor temps. In addition I would recommend eliminating the resonator and muffler or if it is quiet you like then get a walker muffler to replace the oem and still leave the resonator off. Also I like the RE0880 filter.
Any Questions?
Brant
01 Excab 4x4 Driftwood, agate interior, Potect grilleguard, DeeZee FX black, Weatherguard crossbox, Montezuma tool box, Honda air compressor, fold down g/n hitch.
Geno's pillar mount combo guage, HX40, Jardine Exhaust, 5"
chrom tip, PE EZ, Hot PE box, DDIIs, Dunrite TC, Transgo shift kit, and K&N RE-0880 (soon to add Psycotty).
Performance Diesel Dealer
i saw DD3's and an EZ on least aggressive setting put down 303HP at the rear wheels with a 91% DTT TC unlocked also had a K+N RE0880 which was worth 10 hp . though the dyno was not capable of loading enough to get max boost and EGT ran about 1000 , this was with a 4" exhaust and the stock 2000 turbo , on the street this setup has very sane EGT's , if you have a stock exhaust , loose the stock resonator and muffler in favor of a lo restriction muffler .
the EZ actually lowers the EGT making this a great combo , only the insane BOMBer will crave more power than this .
[This message has been edited by Mopar-muscle (edited 04-04-2001). ]
I have 275's a EZ and a regular PE and I can hit 1450 degrees at WOT. But I am going like a bat out of hell when it hits that temp.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station. ZOOM ZOOM
JR2 , whats your altitude ??? actually i did see that temp with almost that same combo , close to sea level , but it was at the end of the 1/4
I AM MY OWN WARRANTY STATION ... when i get caught #ad
[This message has been edited by Mopar-muscle (edited 04-05-2001). ]
CSCpusher, tell me about this ez thats you can get. im interested in it.
(Silver Bullet)1999 Ext Cab 4X4 5SPD, All options. Power Max 3(adjustable), K&N Filter, no muffler, Pyro,Fender Flares, Toolbox, bedrail covers, 450 watt Kenwood Sub, 33 12. 50 16. 5's, 3. 54's... Soon to have: 4inch, DDIII's, Southbend clutch.
Thanks everyone for the input.
I'm going to have CSCpusher (aka Fred) do the DTT stuff the end of this month or the first part of May.
Then Bombs as the skimmin' off the top of the paycheck allows without the wife knowing! #ad
