EZ boost elbow?
Speedometer gear
Grill cover for winter use
Just installed my EZ that arived yesterday. #ad
My questions the boost elbow (install today) seems to just be an elbow with a small hole in the side of it. I was under the impression that the boost elbow was adjustable with a set screw. Did they change the part and how do these things work?
thanks
Ted
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, BD Exhaust Brake, JRE 4" exhaust, SPA, Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
Nope, that's it. Just remove your stock elbow(be sure you keep it in the supplied plastic baggie) and screw the other one in. Hook up the line and its good for about 5 to 7 pounds more boost. Have fun!!!!!
2001 2500 QC, ETH/DEE,4:10s, LSD, EZ with elbow(26. 5PSI)Stage 1 injectors from Carl, Boost/Pyro Guages, 4" Turbo back, BD Brake,Mag-Hytec Cover, Kleen Wheels, Energy Release, 70 gal. fuel, 20K Reese. 31,000 Miles on 03/01/01(Auto/Truck/RV Dealer)
Ted, they did change to the fixed elbow a while ago. I had the same question from HVAC when I first received my EZ. Now, all the boost elbows are fixed, i. e. , no set screw. Just install and go.
Scott W.
Thanks guys. The elbow went in with a set of 275's today #ad
very happy.
Ted
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, BD Exhaust Brake, JRE 4" exhaust, EZ, SPA, Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
Where do you order these from? Have a website for me?
1999 Ext Cab 4X4 5SPD, All options. Power Max 3(adjustable), K&N Filter, no cat or muffler, Pyro,Fender Flares, Toolbox, bedrail covers, 450 watt Kenwood Sub, 33 12. 50 16. 5's, 3. 54's... Soon to have: 4inch, DDIII's, Southbend clutch.
For the Diesel Dynamics version of the EZ go to http://www.dieseldynamics.com/
Don't forget to mention that you are a TDR member for the 20% discount.
I've heard the DD TTPM has a timing only setting which should help with your mileage as well as a 20psi and a 3psi added fueling settings.
Mick
