I'm sure someone here can answer my question. Can the edge ez be run without the boost module hooked up?
The reason I ask, is because from what I've read, it seems that the higher boost can actually give you higher EGTs than in stock form. Will the ECM be able to do its job, if the boost module is not there to override it?
Thanks
Big A
Thanks
Big A
