EZ-Edge (boost elbow)
600 injectors
Cummins 600 rods
Could someone please tell me if my 2004 carb low output (48-E) 3:73's will run better with, or without the edge elbow installed?? I really could not tell the difference after putting it on and am considering putting back stock elbow. . Please help. . Marty
If you are running an EZ, then yes. Keep the boost elbow in. For the most part it just gives you more air to help burn the fuel. Also the more air you pump(to a certain extent) in the cooler the EGT's will be
