Originally posted by Kimber
The 2003 Power Edge EZ has six set points. Check Wildcat.
Originally posted by JHardwick
I don't think 5&6 are gone. I've had mine since July and I have those levels . Oo.
It was on back order at my local dealer, so I know it wasn't laying around in his shop since early on.
Also, how does the elbow help EGT's?
The only thing I see the elbow doing is delaying the wastegate a little. The small hole will take a little longer to allow the 24PSI to pass through, but evenually it will!
Pinch off the wastegate all together![]()
Originally posted by Mopar_Mudder
Where are the 5-6 settings? Mine has pins cut off and I heard that they got rid of them so I just assumed that is why the pins were cut.
Also with the bost elbow you create more boost pressure. More boost pressure equals lower EGT, to a point any way, I have heard that over 40psi you start getting the reverse effect. . Your numbers are wrong, mine will run 38psi of boost under full load, and hold it there as long as you hold your foot down.
If the boost elbow didn't do anything for you do you really think they would go through the trouble of making and having one come with the box.
