Setting #3 is for stock injectors and larger injectors if smoke is not a worry.
setting 3, extrafueling begins at 5 PSI boost
setting 2, extrafueling begins at 10 PSI boost
setting 1, extrafueling begins at 20 PSI boost
The settings are there to allow you to match the fueling curve to your injectors so you can avoid excessive
smoke ( is that possible ??? ) in low boost situations.
The settings have NO effect on the fueling once boost is achieved only how soon the box begins to add fuel.
I may be off a little on the 5,10,20 numbers, but I had a LONG discussion with them regarding how this thing works. BTW, the boost elbow is a good idea. A little bird
told me you could remove the OEM elbow and rubber hose by twisting and pulling the hose off the wastegate while the engine was warm. And then be able to reinstall it if you needed to return it to mother
I wouldnt know...
