Engine/Transmission (1998.5 - 2002) ez map plug years
Engine/Transmission (1998.5 - 2002) Ddiii
It should fit most 2000's and all 01's. Some of the early 00's had the triangle map connector, but most have the flat like your 01. It will not fit 98. 5-99, or 02 for sure.
SEmerson,
I think that I'm correct in that Edge and Blue Chip sell a map sensor adapter that will adapt your 2001 EZ to a 2002. Can't go back in years because of voltage differences. I have a 2001 Edge Comp box that I'd do some trading for your Blue Box/EZ if you are interested, the Comp is less the a year old. Larry
Any EZ or equivalent box with the triangular plug will only work on the 98. 5/00. The ECMs for the 98. 5/00 measure the MAP in gauge pressure. The 01's and up measure absolute pressure form the MAP.
Dean
ez + old style blue box will produce less HP than a drag comp
dyno numbers should be posted in the near future
stay tuned :)
Originally posted by SEmerson
Has any one dynod a ez blue box combo and a drag comp? From what I can find you thay are about the same. Any comments?
These statements and test are difficult on TDR because most folks like what they have or sell and few have tried multiple setups. That said... ... ... ... :) :)
The 4wire Blue Box is adjustable to a peak fueling of 50%, while the Drag Comp is designed to go beyond 50%. My experience is that a Blue Box and a EZ will beat a regular Comp Box but may not a Drag Comp. The Premium Blue Chip FMS will adjust to 63% and joined with an EZ or if running larger injectors I prefer an early VA or Power Puck----will out power a Drag Comp. If you count driveability the FMS wins even bigger. I do not have dyno sheets to prove this (dyno's seem to vary between brands, shops, operators, etc. anyway) but I use a G-Tech, stop watch and recording guages to tyr to find what works best for my setup. If you are running small injectors a Drag Comp 5x5 or FMS on 63% will mostly make more heat at higher rpms while a stock turbo kills the upper horsepower... ... ... ... . so as the saying goes: your results may vary. Larry
It WILL fit an '02 with an adapter. I have one off of an '01 on my '02. I was lucky and found an adapter fo $8-$10. Now they go for $30(+)!!!
DO NOT!!!!!!!!!!!
Pay $30. 00 for an adaptor :eek: there are many place to buy it in the $10. 00 range
whoever is charging $30. 00 is a thief :(
I agree they are a thief, but, what happened is I ordered mine and it came in on the next stock order, and they told be their cost was up to $20 on them, but their website still said $7. 00, and I just checked and it still does, she said it should be up close to $30. I'm not complaining, I got mine reasonable!
