EZ w/ Power Pack
Turbo silencer ring removal
Re-Mapping Controller
Is it possible to combine an EZ With the Power Pack system from Banks?? The trany will be getting upgraded in the next couple of weeks so I shouldn't have any problems here. Will be considering injectors also (stock for now. ) Thanks in advance!!
Chris
It will work but the right way would be to upgrade the injectors to JRE/Bosch 275 hp first, we don't want to try and push alot of fuel through a stock small injector, puts too much load on the pump.
You should consider a JRE pusher pump kit as well to keep up with the fuel demand.
