Details here: TDR Privileges
What the rest of the guys said. It is quite easy to hook up. It has three plugs on it. Two of them are a pass through for the map sensor connection on the truck. You simpily unplug the map sensor, plug in the ez and then plug the stock connection on to the harness. The third plug is for the data port. You take the blank plug out of the data port and plug in the ez. Then you are done. It takes me about 5 minutes to remove mine. Most of the trouble is reaching the plugs without scratching the side of my truck.
Like the guys said... buy at your own risk. . it will lead to more and more and more... .
ty584, it is just like it sounds ez. and it makes it a blast to drive. I got mine from www.piersdiesel.com his ad is in the new issue of TDR on page153. I can highly recommend Piers I had several questions and they answered them all, then they called me to make sure it was working right and that I liked it, also ask for your TDR discount so just do it, and keep that wallet open have fun Oo. Oo. Oo. Don
