Details here: TDR Privileges
What would be more suited to a 3rd gen,with a tst and downloader?My stock intank lift pump pulls down to 2 psi. at wfo. They say the 95 gph is much quiter but will it supply enough fuel?
You should put on the 150gph pump. If noise is a real issue then use a piece of rubber between the pump and truck. Use a piece about 1/16inch to 1/8inch thick sheet made out of neoprene. Thanks
