Factory Oil line connector size
Dual Feed Line from II
Air Filter ?
What is the metric size of the oring fitting that goes in the oil block from the factory for the oil line going to the turbo? I need to get some new oil lines made and do not know what size it is.
TIA
that sounds right. . but i can't 100% confirm it either. just have your line made up with a jic on the engine end, and use an adapter from jic to what ever it ends up being [m12x1. 5 does sound right]
[i can confirm the oil pressure switch is m14x1. 5 and the small plugs are m10x1. 0]
