Factory Tow Hooks - Where Are They Located
Black plastic band on tail gate
Turbo Exhaust Elbow...anyone need one??
I'm going to make my air darn (see separate post) available with cutouts for the OEM tow hooks. I need to know where they are located, along the factory plastic air dam. On the plastic piece on my truck, there is a slightly raised border where it looks like they would be. Is this correct? Do they need the entire cutout, or could I slim the holes down a little?
Hoping people could give me dimensions, pictures, etc. Then I could send a paper template to verify my cutouts.
Please help, and thanks.
That raised border is for the tow hook cutouts. A little "slimming" might be possible, but you might also run into a tolerance problem.
I mounted a set of OEM towhooks and found that, when installed according to instructions, the clearances on the left and right hooks were different. I solved my problem with shimming. However, slight differences in alignment of the hooks will be more apparent with narrow openings than with wider openings.
Air Darn...
I am one with the factory tow hooks and would stay with the outline on the on the factory air dam. Sam
How much do the factory hooks cost? I would like to add a pair myself. After all, a 4x4 vehicle should come standard with these for all of the Phord drivers out there that get in the way. :D :D
Mounting
Next question,
How/where do the tow hooks mount to the frame? Could someone explain, or better, take a picture from underneath?
I am also looking to offer a plate for mounting driving lights. I wonder which factory holes are still available.
Thanks.
get new front bumper
My thoughts. My father has a ford PSD and I felt like dirt when he pulled me out of an embankment while loading firewood up in the woods. He had the nice stock front bumper tow hooks and I only had a piece of plastic held on by plastic coated rivets. Well guess what happened when being pulled at a very sharp angle. Off pops rivets and white hairline crack in gray plastic air darn. What a real blunder on Dodges engineers. Well this person lives about 1. 5 hours from where I live in Indiana makes an awesome bumper with 2" reciever and 2 heavy duty d hooks for front bumpers. Looks good. If you email him, he will send you pictures of it. His email is
-- email address removed --.
Cost is $500 without fog lights and $600 with, but the bumper is now forged steel and bolted on using factory holes without plastic rivets anywhere. Weight is 100#
I'm definetly getting mine ordered because my front bumper looks cheap as it always did.
Louis
