Engin-mounted air compressor
Matches -
I gots a question if ya can relay it to the factory dudes: In the early 90's, on the fleet vehicles with 6BT's, did Cummins produce an engine-mounted air compressor, that bolts up from behind the case cover somewhere in the vicinity of the power steering/vacuum pump location on our engines? AND, if they did, can the power steering and vacuum pump be bolted to the back of that air compressor?
I went to a Kenworth repair delearship a couple days ago and they printed a schymatic of a compressor that apparantly bolted up right where the pwr steering pump goes, but though it looks like the schymatic is displaying for an early 90's 6BT they couldn't tell me for sure.
I -think- the compressor would be found on Ford 650's and 750's, I guess in wreckers and moving vans???
Can anybody shed some light on what make and model a '93 6BT with a factory air brakes would be found in???
Thanks dude - if this works out to all be 'yes', then we have all found a simple, bolt-in way to have onboard air!
Many thanks,
- Sam
