I've read all the posts on this issue. I cannot find a definite answer although the problem seems to be fairly common. Entire brake system has been replaced except for the booster. New rotors,calipers, lines, hoses, wheel cyl, master cyl, drums,pads and shoes. [ $1700] Still have a pedal that is firm ( not hard) at first but with steady pressure will quickly fall away until no pressure. Lines have been bled many times both pressure and with pedal. Master cyl. has been plugged and is firm as a rock. The "ABS" unit on rear frame has been bypassed. At this point my suspicion is the proportioning valve next to the master cyl . Something is allowing the fluid to "recirculate" without creating a leak and this is the only thing left in the system that could do that. Two questions.
Has anyone found this to be the case.
It is a dealer item and discontinued. Where do I get one?
Thanks for any help
Richard Buck
Thanks for any help
Richard Buck
