Driving to work this morning in pouring down rain, my replacement lift pump failed; trouble code P0628. I originally purchased the pump from Genos approximately a year or better ago to be on the safe side, as I was approaching 165K miles on the factory one. My plan was to preserve the old pump and use as spare if needed; glad I did! I re-installed the original pump and after one purging, the truck came back to life.
I'm a little ticked off at the fact that the one from Genos only lasted a fraction of the original! I don't believe the failure to be the direct result of fuel contamination or lack of lubrication as I routinely buy fuel from select major truck stops, drain/replace filter religiously and use additives; I'm not blaming Geno's either. So much for preventive "pump" maintenance.
