rbattelle
In the `03 service manual, where it discusses operation of the factory oil pressure gauge, it says it will read minimum until the pressure rises to 6 psi, after which the needle will jump to approximately the center of the gauge and remain there until the pressure goes above some value (75 psi, I think).
My point is, it looks like this is a false gauge that is calibrated to read in the center (40 psi) no matter what the actual pressure is, as long as it's above 6 psi. In fact, the manual specifically states that the gauge is designed to indicate a pressure "consistent with the owners expectations".
I've heard that the 2nd gen oil gauge was programmed similarly... am I reading this correctly?
If so, good justification for installing an aftermarket gauge.
