the issue i am having dfitzwater is that the exterior temp reading is off due to the plow. the engine and trans are not getting hot. i will check on the tsb for the full clutch lockup next time im at the dealer.
question is - does having a false high reading interfere with interior heat? i believe it does. when the outside (wrong) reading goes above the heat temp i want inside, i believe i am not getting heat. i have also had the ac compressor snowflake show up on the indicator.
I don't have a plow on my 2010 but when the factory winter front was installed and my temp readings were much higher than ambient, I always had good heat. I admittedly don't know how the climate control works so hopefully someone in the know will chime in. SAG? BOB?
TSB # is 07-003-10 and your truck does not need to go to the dealer to try it out:
High coolant temperatures on vehicles equipped with snow plows.
Customers that operate their vehicle with a snow plow attached to the vehicle may cause the
airflow passing through the radiator to be disrupted resulting in higher than normal engine
temperatures. The Cummins ECM is equipped with software that can fully engage the fan
clutch to allow an increase of airflow through the radiator. Customers can initiate the fan clutch
operation by performing the following button sequence:
• Turn the ignition key to the run position or start the truck.
• Simultaneously press and release the Cruise Control “Cancel” button/lever and the
“Exhaust Brake” button. Repeat this sequence four times within five seconds. The chime
will sound twice as an audible indicator that the function is engaged.
• To disable the function, repeat the same procedure. The chime will sound four times as an
audible indicator that the function is disengaged.
Note: ’07-’09 truck engine ECMs were not equipped with the fan engagement software. These
engines would require the latest software update (18-020-10) in order to have the fan-on capability.
Is your heater not work all the time or just when the plow is installed?
