Haven't posted this notice for about a year,talk of grill (winter-fronts) reminded me.
Next time you open the hood ar service check the blades about 1/4 " out from where it is riveted to the center hub.
These are prone to be un-noticed by owners till they fly off, some out there have also lost the radiator and air-air exchanger( aka
heat exchanger--inter cooler).
If the crack is just starting you have to look close (as in my case) but there it was on two paddles.
Also D-aka dc has changed the part number so depending on the age don"t be supprised if you have to purchase the vis drive and blade as a kit. If you were thinking of a course air/horton elect fan set up the cost diff is about $150.
Every time the blake passes the cross bars on the great looking grill the blades are are affected. Like sticking your hand out the window and rotating the palm 90 deg.
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
