can't get fan clutch nut loose! using 36mm wrench & screw driver on water pump bolts. i have soaked the nut several times with sea foam rust buster if anyone knows a better one let me know. standing in front of the truck looking back i'm trying to turn it clock wise to loosen it & back & forth to help break it loose. it's the original fan clutch with 400k miles. appreciate any & all advice thx dansel (1998 12 valve 2500) between a napa fan clutch @ oem which is the better one to use, cummins says they do not supply it it's a dodge product. thxs again dansel (does every one torque the new fan clutch to factory spec's or more, or is there any do's or don't, factory spec's is not much.)
