Engine/Transmission (1994 - 1998) fan clutch nut?????
Engine/Transmission (1994 - 1998) injector retaining nuts
Engine/Transmission (1998.5 - 2002) apps
When standing in the front of the truck, turn it to the right or clockwise. Hit the nut with a drift first. It may be real tight.
Any one have a good idea for braking it loose???????????
My fan clutch is shot. Looks like it was a problem b4 I bought it. It has a new pump and radator.
Like Hemi says
hit it with a drift punch on the right side of the nut as you are standing at the radiator, also get a cheap 1-7/16 wrench, the cheap wreanch will be thinner and allow access past the nuts holding the blade to the hub, put the wreanch on and smack it with a hammer clockwise , hope this helps... ... ... ... . Kevin
I use a big pair of channel locks on the front of the pulley to hold in. Has worked every time but while my '96 is apart I'm going to make a fan wrench that fits over the bolt heads on the pulley.
sounds good, how much air pressure do you use. thx deezul1
Deezul1 is no longer a member, but he is who showed me the air chisel trick when we killed our KDPs years ago. It shouldn't take a lot of pressure. I can back mine off with a long flat screwdriver and a hammer.
