Fan Clutch...
Injector Quality
Engine Dies in Reverse
... whats up with these POS things, pretty sure I just lost another one. Only 7. 5 months and only 22k miles on the stupid thing, why does D/C give us these POS parts??????!!!!:mad:#@$%! Anyone convert over to something else that works???
How does it die? My 06' goes into the dealer on Tuesday for Fan Clutch assembly replacement. Mine makes a periodic crunch/thud sound when the Hvac fan is on. I'm near 32k miles.
This will be the third one I'n replacing. they usually will not engage at idle and as a result the A/C will be hot, I cured this recently with a manual switch to the A/C compressor. I also just hooked up a manual fan override switch (MFO), out playing around when the A/C blowoff valve would let go, too much pressure, so I lift the hood and could not hear the fan at all, truck was straight up at 200* on factory gauge. Brought RPM's up to 3500 fan would engage a few seconds then nothing again, shut down rig and watched fan spin for several seconds afterwards. Go out and spin fan by hand. . around and around she goes! :mad:
All new parts from the dealer are under a 12 month warranty. If you have your receipt and got it from the dealer, take it back (and don't tell them about the MFO).
