Fan control
wheel bearings
Getting a build sheet
The first 3 speeds on my hvac fan died and now all i have is high. is there an easy fix or is it much worse?
It's probably a burned out resistor. You'll find it in the housing right next to the blower motor, which is beneath the glove box. There's an electrical connector that hooks into it.
Remove it, and check resistance across it. My guess is it'll be open circuited. Cheap, easy fix.
Ryan
