CMckee said:you could always just use a 10mm on the bolts that hold the fan unit to the block. there is one bolt behind the pully but with a thin wrench you can get at it no problem. then pull the shroud and the fan out together. i just did this on the weekend while doing my kdp, saves the fught with holding the fan and cracking the big LEFT HANDED nut.
