On my wifes 92 with a little over 110k, I replaced the tensioner pulley assy due bearing noise and belt squeek. About 5k miles later, I had to replace the air condiditoning clutch due to loose bearings making noise.
Now there is bearing noise coming from the fan idler. At first I thought that the water pump was behind the fan. Wrong, the water pump is what I thought was another idler pulley. It looks like the fan is on an idler pulley itself. Is that correct? Can just the bearings be replaced or do I need to get the whole assy from Cummins NW? Do I just remove the belt, unbolt the fan, unbolt the pulley then onbolt the idler assy from the front of the engine?
Thanks for the help
Thanks for the help
