Details here: TDR Privileges
Changing serpentine belt,trying to figure out how to remove or disconnect temp probe or what ever that is connected to front of fan and ties in to radiator shroud. Need this off to slip belt off.
The first time I attempted to replade the fan belt on a friend's '03 truck, I thought the same thing. Once I started removing the belt, I discovered it loops around the fan hub and it's not necessary to disconnect the fan clutch control wire.
I have changed my belt three times on my 05 and never have had to remove these wires. The job is some what challenging due to the lack of space and the way the belt has to go behind the belt tension pulley, but you should not have to remove any wires or parts to get the belt on or off.
