Hello everyone.
I've got a quick question for you. On my 01, the fan will not switch when you change the position (face,feet, combo). It is stuck blowing out at the feet all the time.
I had my evaporator core changed out under warranty a couple months ago, but this just happened, and the 36k warranty is up. The AC works and the fan changes speed, it's just the location of the air I'm having trouble with.
Do you know if this is controlled electracally or by vacuum. Is there something that could have worked loose, or a part that needs to be replaced.
Any help or guidence is appreciated. I want to fix it, but don't want to start tearing the dash apart with a little knowledge.
Thanks
Thanks
