The bearing that the fan hub runs in froze up and locked up the engine. I thought I had galled a piston or spun a bearing because at 65 mph it just shut the engine down. After contacting a dealer I found out they want $76 (dealer cost) for the bearing or $162 for the bearing and housing. I pulled the parts off the engine and did an internet search with the bearing number and it comes up as not available. I will check with Cummins tomorrow. Have any of you had this part fail? It gave no warning at all just froze up solid.
Rod
Rod
