Hello, I am having an issue with my 2007 5.9. The A/C clutch will not engage, I did an Ohm check on the clutch and there is about 10 ohm's resistance so I believe it is ok but I am not sure what the reading should be. While checking codes I found that it had a code for the fan clutch and fan speed. The fan will turn by hand and free spin maybe a half turn. The part on the front of the fan seems loose, I can rattle it when I pull on the wires, I don't know if this is normal.
So I am wondering 2 things, if the part on the front of the clutch is rattling is the clutch bad and second will this prevent the A/C clutch from engaging. The the 2 combined parts will cost a little over $200 I don't want to just throw them at it.
Any help would be appreciated.
Thanks,
Chuck
Thanks,
Chuck
