It sounds like blade tapping on fan shroud. Not engine overhead or rod knock,nothing hitting fan,good clearances around it. When around 2000rpm when is fan on,does it and fades away when fan disengages. Fan is not wobbling, won’t do it parked under same conditions. No cooling problems and a/c is working correctly. Won’t do it all the time.
Sounds same as tapping blade with wrench. Any ideas ? I’m saying it’s fan noise, might not be ? I know it’s a questionable viscous electronic setup.
