I've had a low grade howl in my Farmall H rear end ever since I got it 10+ years ago. There is a round plate on the bottom rear of what is called the "transmission differential and final drive ass'y". I pulled that round plate, a few years ago to drain the beast, (Got 5+ gallons of 90 wt gear lube out of it. ) I fished around a little, inside and found a piece of bearing cage--a big piece--about half of a bearing cage. It was pretty folded up but didn't look ground up. Anybody care to guess just how much of a pain this repair will be? Or... I suppose it is slightly possible that somebody already made the repair and left the cage in there. I didn't find ANY ball bearings or pieces of a race, just half a cage.
The low grade howl is most evident in higher gears and hasn't gotten any worse in 10 years, but it bugs me. Anybody have any Farmall H experience?
I put a new engine in the H in '96 and love the way it runs. It is beat-up and rusty looking--just the way an old tractor SHOULD look, IMTO, but it has a wide front end and a Du-all Front End Loader with which I can raise 500 pounds 14 feet up in the air if I need to.
152 Cubic Inches 6 to 1 compression ratio
I guessing about 15 Horsepower at 1,800 rpm
LOTS of TORQUE
LOTS of TORQUE
