Engine/Transmission (1998.5 - 2002) FASS 95 filters
So I bought a Fass 95 series fuel system last fall, thinking it would be the best thing for lift pump replacement. Well little did I know, the filters are only available through Fass, (or dealers of Fass) so the other day when I punctured a filter I was stranded, looked all over to find a replacement, to no avail. Had I known this I would have NEVER bought this model of FASS pump. Anyone else run into this problem or have a sound solution?
What filters? Does the 95 use the same one's as the 150? I use the FleetGuard HYDRALIC filter, HF 6604 and a FleetGuard water seperator FS 1023, with the drain on the bottom. These are Available from any Cummins shop across the country.
The 95 uses a much smaller filter that the 150, I wish i would have know this from the start! I would have spent the extra few bucks for the 150, Im gonna talk to my vendor tomorrow about it and see about buying a 150 and selling my 95, I love the pump but I'm not gonna mail order filters forever!
Oh, okay. Probably a good idea. Did you ask this question over on BITOG? All those guys do over there is cross reference filters, it's pretty cool. :cool:
Bob Is The Oil Guy - Powered by Motor Oil
Hey, it says on BITOG you can use a FleetGuard FF 5712 filter (3 micron) and a FleetGuard FS 19768 as a water seperator! Maybe worth an investigation at the closest Cummins shop? These two filters fit the FASS 95 Series pump. I'd check 'em out, I don't know.
