FASS and E-Brake.....
tow/haul mode
03 doing wierd stuff?
Has anyone come up with a solution for the minimal clearance between the Cp3 inlet and the vaccum pump for the E-Brake? The 90 elbow FASS provides will not fit. Any Ideas?
i just ran it to the back of the stock filter where the inlet goes into the fuel filter housing on the 06 models so you have a couple of filter for fuel to go thru
That was the only thing I was worried about. I mean having the extra restriction from the small fuel lines from stock filter to CP3
well the lines i got with our fass system was 3/8 which is just slighty bigger than stock and the truck it is on has no problem at all gettin fuel unless you are in a big demand for lots of fuel it won't make a difference just as long as fuel is getting to the pump to be pressurized
See, I am trying to spool twins, and I will be swapping the Edge for the TST which will be stacked with the Bully Dog. THats a lot of fuel!
