I have been doing a lot of reading here on the TDR about how some of you have had trouble losing power from the ECM for the lift pump. I was wanting to use a relay and just use the power from the ecm to pull the relay. I have just installed a FASS DDRP, and I really don't want to cut the wires between the pump and the plug that plugs into the wire harness. Does anyone know if there is anywhere that sells those plugs they use on pumps, I would like to find like a short extension cable that I could plug between the pump and stock harness then cut into the extension for the relay.
I hope this makes some sense to someone, cuz I'm not sure I even know what he heck I am saying.
Tim
Tim
