UPDATE! I performed the "bucket test" as required by FASS to eliminate the pump as an issue. The truck ran fine with full fuel pressure, " except for me accidentally getting air in the line and having to reprime the injector lines"! That told me it was something in the tank. I pulled the bed off and pulled the sending unit out. I found the screen on the bottom of the sending unit black and full of debis. It seemed to be small black sandy/dirt particles and chunks. Cleaned it thoroughly and went to reinstall, when my buddy noticed that the "black stuff " was actually fromthe pick up arm. The black foam like float was worn on each end from 200,000 miles of rubbing around the tank. Thought I would mention this as I have never seen anyone mention this as being a problem. It was all inside the screen and bottom of the sending unit. So after cleaning that mess, I reinstalled everything and now the truck has 20 psi fuel pressure and runs great. Good luck if you're having similar issues. BTW, I had to drive to my buddy's house to use his shop, so I put a fuel hose in a 5gal fuel tank from the FASS to get there. My tank was full and I never thought about fuel returning into the tank. Basically, I left a fuel trail from my house to his from the fuel tank over filling. :-laf
