FASS fuel pressures....
Effect(s) of changing compressor trim on map width/size/quality
Beating a dead horse--need a VP-44 part #
Lately I have noticed a drop by about a pound or so in the last month.
I changed both filter and separator with no real change in pressure.
Is this normal? Maybe a settling of the pump?
I am running about 13. 5 psi. constant.
If you are running an isolator, try refilling it completely with antifreeze. Worth a try. Mine recently dropped from 17 to 9. After changing the prefilter, main filter with no difference, I filled up the isolator on my Di Pricol gauge and it came right back up. Good luck.
