I've been doing a lot of reading on past forum posts, but I haven't found the answers I've been looking for, so here we go.
I installed a FASS HPFP 95 on my truck yesterday. I bought it through Rover Hybrids, so that it comes with a 2 year warranty running WVO, although I have set it up to pull from the diesel and WVO tanks. The truck was running fine before I put the FASS in, just the other lift pump was pretty weak. The FASS is supposedly set at 18 psi, although it is running around 26 psi at idle, low 20's driving, and high teens at WOT.
So now, on the the problem. It starts hard if I let it sit a while. I wired the FASS off the original LP wiring harness, so it runs for a second once I turn the key, builds about 3-4psi, then shuts off until the engine is running (I noticed on past posts that it was recommended to have low IP inlet pressure while starting). It actually seems more like I'm getting air in the system. If I shut the truck off, then restart it again, it fires up no problem, even if I bump the starter so it builds full pressure. Once it's going, it runs fine, it just suddenly doesn't like to cold start.
Thoughts?
Thoughts?
