Archived FASS help
Archived No wipers
Directions say "Disconnect factory fule line from inlet side of factory injection pump (note: this is where the suction fuel line from the fuel filter enters the injection pump). On my 01, is this where the schreader valve is or the other line thats towards the front of the truck (next to it)? Thanks in advance for any help!
The Banjo Fitting with the Schrader valve is the correct port. The Banjo Fitting in front of that one is the check valve that controls pump housing pressure. Do not use that port.
Have A Nice Day
