Hey guys I've had a Fass II on my truck for about 6 months now and when I first got it my idle pressure was around 13psi and went down to about 11psi when I got on WOT. So I called where I got it and he sent me a new spring which then put me up at 17psi idle & no lower then 14psi at WOT... Over the past few months the WOT pressure has been dropping slowy and now is around 10psi with the Comp box untapped with the fueling set to come on early. . I upgraded all my fuel line from the tank to the Fuel Filter with 3/8" hose that came with the FASS II and yesterday I upgraded the hose between the Fuel Filter to the VP44 with the Vulcan Big Line Kit and my FP is being monitored between the Fuel Filter & the VP44... .
So I am a little worried about when I tap the pump wire my FP will drop way below 10psi. From a stop pulling away from a stop sign on level ground it hardly moves at all maybe drop a pound or so... But as soon as I give it more fuel it drops to about 13psi and if I got to WOT it drops to 10psi... I have a message in to the guy I bought it from so I will ask him as well, but I wanted to see what you guys think as well. . It almost seems like there may be a restriction some where maybe in the pickup screen in the tank??? It almost has to be something in the tank because I just changed my Fuel filter not to long ago. Does anyone have any other ideas or suggestions?
Thanks, Engcogod
Thanks, Engcogod
