2nd Gen Non-Engine/Transmission Fass Ii Pump Vibrateing And Making Noise
Engine/Transmission (1998.5 - 2002) 6.0 injectors
Engine/Transmission (1998.5 - 2002) VP44,Play It Again
MY FASS II PUMP VIBRATES AND MAKES NOISE SO LOUD IT COVER UP THE SOUND FROM THE ENGINE
AND THE TRUCK HAS STRAIGHT PIPE ON IT
IF I TAKE THE BRACKET OFF AND CUSHEN IT WITH SOME TYPE OF TAPE
WILL THIS STOP THE VIBRATION AND NOISE
OR IS IT SOMETHING OTHER THAN THAT IT HAS 14 TO 15-1/2 PSI AT IDLE
AND 13 WIDE OPEN I DON'T GET IT
IS IT THE FUEL I DON'T KNOW :confused:
Almost sounds like it might be cavitating... but you seem to be holding good pressure...
I know I have read a lot of threads about guys bolting noise deadening material between the bracket and frame... I also remember one using multiple wraps of black electrical tape...
I always thought about a piece of rubber mudflap...
steved
Brad has a new intermediate plate that mostly fixes this problem. I have a few that he has sent me. They are in short supply but I am sure he will be getting more. Thanks, Brady
