Installed my FASS pump today. I noticed the fuel line they give you is 3/8" id and so is the steel factory line. I used the hose they supply to connect tank to pump and pump to steel line. I then plumbed in a tee fitting at end of steel line to give me pressure to gauge in cab. I used their hose from tee to injector pump. I can only assume that fuel flow will be the same. Anybody put one in yet?
