FASS is installed
Trouble Codes
Edge EZ Settings
works great. 18 psi nevers goes below 15.
Has anyone installed a belly pan to protect it from road grime and bad weather? I'm thinking of installing a snap on plastic box over the fuse and wire connectors for added protection.
Had mine installed about 10 days ago. Same 18psi, except I can drop it to 13psi for a few seconds on WOT now before it goes to 15. The first full tank after install and driving the devel out of it, 10-11 1/4 track runs, playing with the new turbo and boxes up all the way about half the time my mileage was above normal driving mpg. It should have been 2+mpg lower with the type of driving. I do believe the FASS had a hand in that.
Bighorn - how difficult was the install? (Did you do it yourself or have a shop do it?). How are the directions that are provided? Any tricky points that require independent thinking (that side of my brain doesn't work)?
I'm sure that my rig would benefit from a FASS system, just not sure if I'm up for the challenge.
Thanks for the info,
- Jason
