I tried to find my receipt for the FASS to see how long it has been on the truck. No luck. I'm guessing it has to be close to 10 years though.
I've noticed increasingly inconsistent fuel pressures probably for the last 6 months. Never a no-pressure situation, though. No drivability problems, until a couple of weeks ago during a cold snap. I had to move the truck out of the garage and it took a lot more cranking to get it fired up than usual. When I went to move it back into the garage, it refused to start, period. Cranked but no sign of lighting off, and essentially no fuel pressure. As an aside, the batteries were replaced at that time. They were 8 years old and just that little extra cranking showed they were needing replacement.
When you bump the key it won't produce over about 3psi according to the gauge, and the pump sounds like it is not under load. I assume it has lost its prime.
If you crack the line at the injector pump and bump the key, it will dribble for a few seconds, and then it is like the pump gets traction and takes off, producing 15+psi. Then the pump signal times out. When you bump it again with the system sealed, it again fails to produce more than ~3psi and fails to start. So, if it is a lost-prime situation, it immediately loses prime.
The only thing I've don so far was replace the filter and water separator. They were due to be changed, but it made no difference.
Any suggestions?
Any suggestions?
