Any one running this filter before there fass?
Vulcan Performance In-Line Fuel Filter 35 Micron w/ Push Locks
Thanks for the input Dan. What pre filter/strainer would you recommend? I would like too use one that does not use hose clamps, either push lock fitting or threads.
I have just the fass pump no filters. I was wanting to do away with the Napa strainer that came with the fass pump and go with something like an inline or spin on pre filter/strainer using a remote mount filter base Baldwin FB1311 Filter and a strainer Baldwin BF7759 Filter
Does the FASS (not the HPFP, but the unit with the wather sep and filter) need a prefilter? I'm not sure how the internal plumbing is set up. Does it pull raw fuel into the unit and then push it through the water seperator and then the filter? Or is the fuel sucked through the seperator and filter and then pushed up to the VP44? If it's the later, doesn't seem to be any need for a prefilter. Seems like there's quite a few folks running them with the Draw Straw II straight from the tank which bypasses the factory screen in the fuel module and I've not heard of any problems.
Dan,
How often should the WS be replaced? I have had it a year so far. . Have emptied it a few times with no debris coming out... Guess that means my tank is pretty clean. .
Is there a local place in Salt Lake City to get these filters and WS's?
Well we use NAPA inline strainers in our kits. We found these to be cost effective and work great. But they are a clamp on style. This works just fine... but its not a flashy as the others.
Dan, Do you have a Part # for this Napa strainer???
Is this the best piece for the least amount of PSI dropage???
Michael
