Engine/Transmission (1998.5 - 2002) FASS Pressure increase
Engine/Transmission (1998.5 - 2002) What do you do to fix a P1596?
Engine/Transmission (1998.5 - 2002) Piston Cooling Jets
Can anyone point me in the direction on where I can get say 17-20 Psi springs for my 150 FASS... ... any help is appreciated!... ..... Jeremy
Piers Diesel sells them and just about anywhere that sells the FASS should have or be able to get them.
I just removed the stock spring and stretched it about a 1/4 inch or so and that bumped me from 12psi to 15psi. Did that about 2 years ago and it is still the same. Just FYI.
Hope this helps
J-
My FASS spring was also recently stretched. It went from 13psi stock to 17psi. It's holding there fine at the moment.
