just installed a fass on my truck now it will not start. a soon as i try to start it the fuel pressure climbs to 19 lbs , the way i understand, it is to high of pressure for the vp. i can take the fuse out of the fass wiring then start the truck and run around and put the fuse in and then it's fine. but i'm running 19 lbs at idle and about 17-18 at wide open. one local shop suggested i put a swith on the fass line running to the bat. and turn it on after the truck has started but this all doesn't seem right after all i have spent ($$) on this premo setup. any advice.
