fass problems
$ for hx35 12WG housing??
VA or TST or ?
Oo. how many people have had trouble with the fittings on there pump? the one i just installed broke the fitting on the return line side(the one that has a 3/8 nipple on it)---, it just pulled right out. i have had this happen a few times now---whats the deal, poor quality? :confused:
Maybe a mention in the instruction manual about that fitting would be helpful. Of course, you are probably swapping springs out again, so it is on its 3rd or 4th re-torque and the manual hasn't been consulted since the initial install, so that wouldn't help in this case. ;) About 8 to 10 ft lbs of torque, if that, is all that fitting is designed to need to make a seal. It is a very soft brass sealing surface and is meant to be smashed against the nipple to make a seal. Ask it to take 50 ft lbs of torque so it doesn’t leak and that is what happens every time. That fitting should be accompanied with a tag that says "WARNING DO NOT OVER TORQUE WITH UNCALIBRATED MAN-HANDS" :-laf
haha, im not that stupid--18lbs is what it calls for, this was on a customers truck not mine. i thredded it on by hand and it came apart. wierd huh. oh well got another one and im good to go now. :-laf
Diesel_Dan said:
I have not heard any about this issue. We have 1000's of thoes fittings and have never had one do what you said. BUT i will make a note and check in to it. Just watch your torque when you do tigthen it up... . takes a lot less than what you would think. But i will look at our fitting a bit closer tom... thanks for bringing this to my attention...
dan i appritiat your response, you may also want to look into the pump bodys leaking----looks like there is no gasket where there should be one, so its leaking---and on its way back to you very soon. thanks :cool:
